查看: 4749|回覆: 3
Analog公司的Op Amp Applications Handbook.
發表於 2012-11-9 06:56:09 | 顯示全部樓層 |閱讀模式
本帖最後由 scottwang 於 2012-11-9 07:04 AM 編輯
好料的Op Amp應用手冊.
內容:
Op Amp Applications Handbook - First Printing Errata (pdf, 171 KB bytes)
Front - (pdf, 115 KB)
Section H: Op Amp History - (pdf, 3608 KB)
Section 1: Op Amp Basics - (pdf, 1681 KB)
Section 2: Specialty Amplifiers - (pdf, 671 KB)
Section 3: Using Op Amps with Data Converters - (pdf, 571 KB)
Section 4: Sensor Signal Conditioning - (pdf, 756 KB)
Sections 5-1 to 5-4: Analog Filters - (pdf, 3004 KB)
Sections 5-5 to 5-8: Analog Filters - (pdf, 1535 KB)
Section 6: Signal Amplifiers - (pdf, 3976 KB)
Section 7: Hardware and Housekeeping Techniques - (pdf, 2776 KB)
Index - (pdf, 294 KB)
Op Amp Applications - zip file of entire book - (17 MB bytes) - (前面所有檔案的壓縮檔)
發表於 2012-11-9 07:37:13 | 顯示全部樓層
好東西,值得參考!謝謝##
發表於 2012-11-9 08:09:10 | 顯示全部樓層
不錯的資料、留下參考~~~謝謝
發表於 2012-11-9 08:16:48 | 顯示全部樓層
好文件,還要用功,再加上努力.才能吸收應用.
GMT+8, 2026-10-29 10:05 PM , Processed in 0.020777 second(s), 5 queries , Gzip On, Redis On.
