2026-11-18 19:38:21 Warning: Secure Kernel reinstalled
A distro kernel update had removed the CWP Secure Kernel from this server (installonly rotation). CWP reinstalled it (4.18.0-553.180.1.el8_10.cwpsec.x86_64) and set it as the boot kernel; reboot to restore Secure Kernel protection.
處理方式︰inbus 表示需有購買security kernel 才會用到,故先不理會。
2026-11-18 19:41:20 Warning: CWP Security Audit - Root SSH password login enabled
sshd permits root to log in with a password (PermitRootLogin yes). This is how several compromised servers were brute-forced to root. Switch root to key-only (PermitRootLogin prohibit-password) or disable password auth, and make sure CSF/LFD brute-force blocking (LF_SSHD) is on. (Sent once per finding.)
處理方式︰找時間了解怎麼將 root 使用者切換為僅金鑰登入(PermitRootLogin prohibit-password)或停用密碼驗證。
2026-11-21 19:36:17 Danger: Hidden Processes - SECURITY ISSUE
Hide all processes if not owned by the user is NOT activated on your server, click here to enable it.
處理方式︰inbus 表示我們只有一個使用者,所以沒關係。故先不用理會。
