樓主: duke83
[電子儀表] 高感度指針萬用表 SANWA N-501D
發表於 2023-5-1 15:23:14 | 顯示全部樓層
duke83 發表於 2023-5-1 12:19 PM
我前面有講過以前我有拆過各種指針錶,來源都是廢五金所以品相都不好,但是都是練手的好材料。
所以大致 ...
有幸國外很多熱心網友及機構掃描並保存了很多手冊、期刊、文檔等,現今我們才能獲得許多資訊,沒有失傳。
Simpson 大表頭機型當年的價格整理如下,也列出幾個 260 的價格供參考比較
Simpson analog multimeter price (history)
Classical 260 for reference:
Simpson 260    $43.95  1957 sales brochure Bulletin no. 2058
Simpson 260-5  $49.95  1966 HRFE
Simpson 260-5P $78.95  1966 HRFE, 1964 Simpson Test Equipment Bulletin No. 2066
Simpson 260-5P $97.00  Electronics World 1971-03
Simpson 260-5PRT $84.95  1964 Simpson Test Equipment Bulletin No. 2066
* P = Overload Protection
Large, easy to read 7" scale meters:
Simpson 262    $59.50  1957 sales brochure Bulletin no. 2058
Simpson 262    $69.95  Simpson Test Equipment Bulletin No. 2064A
Simpson 262-2  $69.95  1964 Simpson Test Equipment Bulletin No. 2066
Simpson 262-2  $69.95  1966 HRFE
Simpson 262-3  $70.00  Electronic Design V14 N28 1966-1206
Simpson 263    $78.95  1964 Simpson Test Equipment Bulletin No. 2066
Simpson 263    $78.95  1966 HRFE
Simpson 263    $85.00  Electronic Design V14 N28 1966-1206
Simpson 267    $54.95  Simpson Test Equipment Bulletin No. 2064A
Simpson 267    $54.95  1964 Simpson Test Equipment Bulletin No. 2066
Simpson 267    $59.95  1966 HRFE
Simpson 268    $54.95  Simpson Test Equipment Bulletin No. 2064A
Simpson 268    $54.95  1964 Simpson Test Equipment Bulletin No. 2066
Simpson 268    $59.95  1966 HRFE
Simpson 269    $88.00  1956
Simpson 269    $88.00  1957 sales brochure  Bulletin no. 2058
Simpson 269    $89.95  Simpson Test Equipment Bulletin No. 2064A
Simpson 269-2  $89.95  Simpson Test Equipment Bulletin No. 2066
Simpson 269-2  $89.95  1966 HRFE
Simpson 269-2  $90.00  Electronic Design V14 N28 1966-1206
Simpson 269-3  $98.00  Electronics World 1971-03
Simpson 269-3  List $218 Sale $196  Radio Electronics 1983-09, 1983-10
Simpson 269-3  $125    Antique Radio Classified 1990-02  (這期刊主要是分類ㄍㄨㄤˇ ㄍㄠˋ   Classified Advertisement)
Simpson 269-3  £45 (new)  Wireless World 1995-10
262,267,268: DC 20K/V AC 5K/V
263:         DC 20K/V AC 10K/V and DC 10K/V AC 5K/V  (similar to AVO's "÷2")
269:         DC 100K/V AC 5K/V
262,269: 1.6-8-40   scale
263:     3-75, 6-15 scale
267:     2.5-10-50  scale
268:     3-12-60    scale
Scale length: 6.2 inches
Dimensions: 6" x 7 1/2" x 3"
Net weight: 4 lbs.
Thanks to all the persons who scan and keep these antique electronic manuals, periodicals, brochures, documents, etc. and share them online, so that we can get a lot of useful information.
1956 年的  $88 相當於 2023 年的 $974
1971 年的  $98 相當於 2023 年的 $730
1983 年的 $196 相當於 2023 年的 $594
看了一下 1956 美國人收入中位數 $3600(男)$1100(女) 同年台灣平均國民所得 NT$3318=US$137
當年的差距相當大啊
發表於 2023-5-3 21:28:50 | 顯示全部樓層
我有兩部sanwa 501-zx-tr , 因為買不到22.5v電池 , 也高懸儲藏櫃N年了,
 樓主| 發表於 2023-5-3 22:31:06 | 顯示全部樓層
creekse 發表於 2023-5-3 09:28 PM
22.5V 積層電池可以自己造啊,我是用七顆 CR2032 裝在合適的塑膠殼內就解決了。
有高電壓輸出的電表ㄧ些場合很方便很好用的。
發表於 2023-5-4 05:38:08 | 顯示全部樓層
22.5V 電池,淘寶、露天有售。(由於是特製品,金屬外殼是沿用 6F22 的,加印或加貼22.5V)
發表於 2023-5-4 21:46:33 | 顯示全部樓層
duke83 發表於 2023-5-3 10:31 PM
有高電壓輸出的電表ㄧ些 ...
我之前有想過,用兩個27A電池改裝,再修改一下阻值,但都沒動手,
時過境遷 量測晶體漏電 雜音的機會少了,就束之高閣閒置了.
是看到你的501,才又讓想起我的501
發表於 2023-5-4 21:48:14 | 顯示全部樓層
tonysun 發表於 2023-5-4 05:38 AM
22.5V 電池,淘寶、露天有售。(由於是特製品,金屬外殼是沿用 6F22 的,加印或加貼22.5V) ...
感謝 ,是該買一個來補齊裝備
感謝
發表於 2023-5-4 22:07:14 | 顯示全部樓層
看了各位前輩的收藏有一個"感想",就是"生不帶來,死也帶不走"!! 很多骨董會因為兒孫沒興趣而再度"換人收藏"!! 活在當下!!
 樓主| 發表於 2023-5-4 22:24:07 | 顯示全部樓層
本帖最後由 duke83 於 2023-5-4 10:39 PM 編輯
antlu 發表於 2023-5-4 10:07 PM
看了各位前輩的收藏有一個"感想",就是"生不帶來,死也帶不走"!! 很多骨董會因為兒孫沒興趣而再度"換人收藏"! ...
沒錯,我的辛普森就是這樣拍來的,換我用個幾年後玩不動時希望還會有人有興趣能繼續流傳下去。
所以指針錶不要只拿來收藏要拿出來用才會有真實價值,也要選擇有特色最好是一時之選的機型才能玩的開心。
現在平常儘量不用數字表除非要精密量測,指針錶還是可以承擔七成的量測工作。
類比的指針顯示還是看的比較踏實,對於我這種沒有數字觀念或記憶的人,可以看著指針的位置能就有良劣好壞的判斷。
 樓主| 發表於 2023-5-4 23:06:03 | 顯示全部樓層
creekse 發表於 2023-5-4 09:46 PM
時過境遷 量測晶體漏電 雜音的機會少了, ...
這種 27A 電池盡量少用裏面是會漏酸氣的 LR44,而且一次就用到 8x2=16 顆內部被氧化的機率更高。
一次鋰電池相對是比較安全的但要自己包裝加工。
或是採用兩顆金頂 9V 串連也可以應該不用改到電阻,金頂方形 9V 不像平常 3 號惡名昭彰電池不會漏液且電量充足。
對岸生產的 22.5V 電池我是不敢用,電表比較寶貴要多考慮一下。
發表於 2023-5-7 14:07:52 | 顯示全部樓層
我都有部sanwa 501-zx-tr,至於22.5V電池市面仍有出售,只是款式很少可選擇,在網路上或淘宝都可找到。
發表於 2023-5-7 14:20:43 | 顯示全部樓層
duke83 發表於 2023-5-4 11:06 PM
一次鋰 ...
我用過23AE,圖中六枚23AE已用約十年了,最近醒過來要檢查一下才知沒電要換新的,約十年過了電池沒有漏液,這類GP 23AE電池應可信賴。
發表於 2023-5-7 14:32:03 | 顯示全部樓層
淘宝有買過15V電池,試過有些會漏液亦試過有些不會漏,漏不漏真的全是運氣。
方形的15V電池已用約五年,暫時未漏液,但已沒電了。
發表於 2023-5-7 16:40:53 | 顯示全部樓層
今日終於將在床底的Simpson 269 series3翻出來,原因是想比試一下Simpson 269(是第一代,軸承游絲表)及269 series3(張絲表)的指針反應速度。
兩個269是同時接上信號產生器,產生器會出一個DC 8V,看看游絲表的反應是否比張絲表快很多。
的確是游絲表的反應是比張絲表快些,但269游絲表的指針會有過衝情況,指針過衝後是要返來回一下才停下來,而269張絲表完全沒有過衝擺動。
Simpson 269 series3滿度偏擺大約需要三秒,而Simpson 269游絲表亦要接近三秒,兩個表排站在一起測試是會見到兩個表的指針是幾乎是同時停止的。
張絲一向給人有反應較慢的感覺,但Simpson張絲表的速度表現不會比自家的游絲表差。
 樓主| 發表於 2023-5-7 19:13:21 | 顯示全部樓層
msko2003 發表於 2023-5-7 04:40 PM
今日終於將在床底的Simpson 269 series3翻出來,原因是想比試一下Simpson 269(是第一代,軸承游絲表)及269  ...
我的反應速度測試也是使用 8V 檔搭配使用計時碼表,一隻手按 8V 開關另一隻手按碼表,測試五次取排除手眼協調的反應誤差,應該是用錄影逐幀檢視才是標準,當時只是為了跟 N-501D 比較誰慢誰快,果然辛普森沒有讓人失望是 2.3 秒 與 2.8 秒的差異,這個數值可能不是很正確但還是能夠證明大表頭的指針電表的確比較慢。
 樓主| 發表於 2023-5-7 19:38:57 | 顯示全部樓層
本帖最後由 duke83 於 2023-5-7 07:57 PM 編輯
msko2003 發表於 2023-5-7 02:20 PM
我用過23AE,圖中六枚23AE已用約十年了,最近醒過來要檢查一下才知沒電要換新的,約十年過了電池沒有漏液 ...
多年前曾在台灣的 GP 電池代理商公司中做過市售電池的幾項測試,當時港商陸製 GP 電池剛上市必須對自己的產品了解才能解答經銷商的疑惑。
其中一項就是電池密封度的檢驗,沒有預算送去檢驗單位驗就自己想方法簡單檢驗,使用雙層密封帶內放測試電池與酸鹼試紙,定期觀察紀錄酸鹼試紙的變化程度。
果然其中有幾款電池包含 LRˋ44 酸鹼試紙的反應的確比較快速密閉性普遍上輸日製電池,當時日本流行上頭標示補償(賠償之意)兩字就像這帖主樓照片中的 N-501D 原機電池,或許近年來這方面已經有改善我不知道,但我還是比較信任某幾個品牌型號的電池。
漏液與漏氣只是程度上的不同,近年來電池廠知道密封的成本高改從化學成份的改變,儘量讓電池漏液時不要讓電器腐蝕的太嚴重。
發表於 2023-5-7 19:57:16 | 顯示全部樓層
duke83 發表於 2023-5-7 07:13 PM
我的反應速度測試也是使用 8V 檔搭配使用計時碼表,一隻手按 8V 開關另一隻手按碼表,測試五次取排除手眼 ...
要反應快一定細表比大表好,以下的細表一秒內必攪定。
 樓主| 發表於 2023-5-7 20:14:58 | 顯示全部樓層
你的 269-3 好靚啊!難怪要藏在床底下,讓人直流口水。
發表於 2023-5-8 00:40:36 | 顯示全部樓層
duke83 發表於 2023-5-4 10:24 PM
所以指針 ...
記得高中畢業後去當學徒,電機公司老闆是留日的,用的電錶 是 YEW 橫河電機製作所 很漂亮,那時候只能遠看, 前幾年在新竹回收場 都見不到"骨董"!!
 樓主| 發表於 2023-5-8 05:00:20 | 顯示全部樓層
本帖最後由 duke83 於 2023-5-8 05:30 AM 編輯
antlu 發表於 2023-5-8 12:40 AM
記得高中畢業後去當學徒,電機公司老闆是留日的,用的電錶 是 YEW 橫河電機製作所 很漂亮,那時候只能遠看,  ...
以前台灣民間使用的電表大都是台製 360 或 370 系列的,連三和表都難得一見。
公司使用的電表與公司文化、代理的商品有絕對關係,例如軍中使用美製裝備就會配備美製電表,包含中山與聯勤自己搞研發武器的也是使用美製電表,買下整條生產線時包含技術與使用儀表。
這些美製裝備面臨汰除之時也不會流放到外面的回收廠,有自己專門的回收廠可以回收到許多的金銀等貴金屬。
這台 N-501D 的原使用單位我猜可能不是自己花錢買的,原使用單位是使用日商 NEC 的機器所以搭配三和高感度的有源電表也是合情合理的,極可能是 NEC 隨裝備附送的,其生產製造年代是相符的。
現在這些單位已都轉用德製裝備所以儀表也都轉向使用 R&S 廠牌,我對 R&S 有點感冒雖然規格很好但可靠度偏低又很難維修。
GMT+8, 2026-11-16 01:43 PM , Processed in 0.035153 second(s), 12 queries , Gzip On, Redis On.
