樓主: wish
請大家協助看Yahoo廣告會不會卡
發表於 2012-5-29 00:18:47 | 顯示全部樓層
通報一則廣告BUG
我是網路原始人 能提交的資料如下:
發生時間  2012-05-28    22:30
上圖 是 YAHOO 廣告 點選Housefun
YAHOO HOUSEFUN
YAHOO HOUSEFUN
試過3次一樣問題如下  (點YAHOO 其他廣告   OK沒問題 )
BUG HOUSEFUN
BUG HOUSEFUN
=======這是助我 私房錢多永不被捉    的分隔線=========
點選Housefun 之後的連結網址
http://fix.housefun.com.tw/?WT.m ... 080541&OVKWID=0
=======這是助我 小三多多永不被捉    的分隔線=========
複製後以文字 重貼如下
Server Error in '/' Application.
Runtime Error
Description: An application error occurred on the server. The current custom error settings for this application prevent the details of the application error from being viewed remotely (for security reasons). It could, however, be viewed by browsers running on the local server machine.
Details: To enable the details of this specific error message to be viewable on remote machines, please create a <customErrors> tag within a "web.config" configuration file located in the root directory of the current web application. This <customErrors> tag should then have its "mode" attribute set to "Off".
<!-- Web.Config Configuration File -->
<configuration>
    <system.web>
        <customErrors mode="Off"/>
    </system.web>
</configuration>
Notes: The current error page you are seeing can be replaced by a custom error page by modifying the "defaultRedirect" attribute of the application's <customErrors> configuration tag to point to a custom error page URL.
<configuration>
    <system.web>
        <customErrors mode="RemoteOnly" defaultRedirect="mycustompage.htm"/>
    </system.web>
</configuration>
=======這是助我   99凍蓋固    的分隔線=========
=======這是          純純Pure     的分隔線=========
發表於 2012-5-29 00:23:43 | 顯示全部樓層
SIMON1016 發表於 2012-5-29 12:18 AM static/image/common/back.gif
通報一則廣告BUG
我是網路原始人 能提交的資料如下:
那是語法錯誤吧
但是沒關係... 有經過Yahoo伺服器應該會紀錄
還是會算進去的!!
我之前還遇過連過去說找不到網頁
發表於 2012-5-30 01:16:36 | 顯示全部樓層
網路用的是豐盟,6M,用IN8,試開正常。
GMT+8, 2026-11-21 08:14 PM , Processed in 0.017583 second(s), 5 queries , Gzip On, Redis On.
