查看: 5324|回覆: 4
有人想看笑笑羊嗎???
發表於 2011-5-15 00:21:26 | 顯示全部樓層 |閱讀模式
想看的人可以幫忙分流一下嗎??
http://www.xun6.com/file/e42188112/wJutgTetgn.rar.html
發表於 2011-5-15 10:50:47 | 顯示全部樓層
說真的BT比較不好下除非碰到大水管種子不然就有罪受
樓主您盡可能找MU(可用JDownloader下)或115(專用軟體優蛋)空間比較好下
我試貼喜羊羊MU空間您試下看看1280X720P(比較舊一點電腦還跑得動486與P4早期絕對不行)
http://www.megaupload.com/?d=NSBXTJUC
http://www.megaupload.com/?d=CX4KSFA3
http://www.megaupload.com/?d=I2BLELID
格式:
Format                           : Matroska
File size                        : 2.16 GiB
Duration                         : 1h 27mn
Overall bit rate                 : 3 535 Kbps
Encoded date                     : UTC 2011-03-06 12:21:13
Writing application              : mkvmerge v4.4.0 ('Die Wiederkehr') built on Oct 31 2010 21:52:48
Writing library                  : libebml v1.0.0 + libmatroska v1.0.0
Video
Format                           : AVC
Format/Info                      : Advanced Video Codec
Format profile                   : High@L3.1
Format settings, CABAC           : Yes
Format settings, ReFrames        : 4 frames
Format settings, GOP             : M=1, N=32
Codec ID                         : V_MPEG4/ISO/AVC
Duration                         : 1h 27mn
Bit rate                         : 2 778 Kbps
Width                            : 1 280 pixels
Height                           : 720 pixels
Display aspect ratio             : 16:9
Frame rate                       : 23.976 fps
Color space                      : YUV
Chroma subsampling               : 4:2:0
Bit depth                        : 8 bits
Scan type                        : Progressive
Bits/(Pixel*Frame)               : 0.126
Stream size                      : 1.66 GiB (77%)
Writing library                  : x264 core 112 r1867 22bfd31
Encoding settings                : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=4 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=2778 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Audio
Format                           : DTS
Format/Info                      : Digital Theater Systems
Codec ID                         : A_DTS
Duration                         : 1h 27mn
Bit rate mode                    : Constant
Bit rate                         : 755 Kbps
Channel(s)                       : 6 channels
Channel positions                : Front: L C R, Side: L R, LFE
Sampling rate                    : 48.0 KHz
Bit depth                        : 24 bits
Compression mode                 : Lossy
Delay relative to video          : 6ms
Stream size                      : 472 MiB (21%)
Title                            : DTS
Language                         : Chinese
發表於 2011-5-15 14:07:54 | 顯示全部樓層
不過這些在pps上就有了,小朋友都開pps給他們看,
要不然全下可要花不少時間啊!
 樓主| 發表於 2011-5-15 14:15:04 | 顯示全部樓層
yoyomay 發表於 2011-5-15 02:07 PM static/image/common/back.gif
要不然全下可要花不少時間啊! ...
真的嗎???
我就是在pps找不到才會去找載點的xd
發表於 2011-5-15 14:27:15 | 顯示全部樓層
回復 e0982296321 的帖子
剛剛看了一下,確實有,內地是叫「小羊肖恩」
e0982296321 大你試一下。
GMT+8, 2026-11-20 05:41 PM , Processed in 0.024388 second(s), 8 queries , Gzip On, Redis On.
