查看: 7348|回覆: 2
(轉載)簡單又便宜的汽車防盜器。
發表於 2011-3-28 19:53:24 | 顯示全部樓層 |閱讀模式
本帖最後由 py924 於 2011-3-28 07:55 PM 編輯
小弟才學疏淺,實在看不出來這是什麼用途,可以請瞭解的大大解釋給大家聽嗎?謝謝在先了。
轉載出自:
Simple, inexpensive vehicle immobilizer
  This vehicle immobilizer circuit is quite possibly the smallest, simplest, cheapest and easiest to make, install and operate.Thoroughly field tested, robust and weather resistant design of vehicle immobilizer which can prevent vehicle theft even if thief has keys!
http://home.clear.net.nz/pages/dandavies/images/g-spot_in_hand.jpg
Here's the fancy, animated schematic:
http://home.clear.net.nz/pages/dandavies/images/schematic_ani.gif
These are all the electronic components required:
http://home.clear.net.nz/pages/dandavies/images/danz0040.jpg
and these are all the mechanical components:
http://home.clear.net.nz/pages/dandavies/images/danz0037.jpg
apart from these, a soldering iron, solder, heat source, fiberglass resin (and hardener) plus some lacquer and cleaning solvent - that is all that is required!
See http://home.clear.net.nz/pages/dandavies/index.htm for full assembly/installation details - or, alternatively you can watch this YouTube video showing the construction of a similar product which uses leaded components instead of surface-mount ones - and no PCB or diode is used either.
YoyTube 影像:
http://www.youtube.com/watch?v=FFb5_mKfnR8&feature=player_embedded#at=23
發表於 2011-3-28 20:21:01 | 顯示全部樓層
在下看起來像是安裝一個暗鎖.
安裝之後,必須碰觸這個東西,汽車的電源才會導通,之後才能發動引擎.
如同影片最後用燈泡測試,碰了之後燈泡就亮了.
發表於 2011-4-5 13:52:51 | 顯示全部樓層
若是暗鎖  那裝一個開關不是比較簡單
可能他訴求是觸碰吧
GMT+8, 2026-11-23 08:19 AM , Processed in 0.015757 second(s), 4 queries , Gzip On, Redis On.
