查看: 5920|回覆: 2
威盛主機板1.5GHz VIA C7-D Processor
發表於 2011-1-2 22:00:25 | 顯示全部樓層 |閱讀模式
本帖最後由 benben17 於 2011-1-3 12:08 AM 編輯
配件sata線一條ide排線一條
有測試過開機正常
由於是出清所以沒有保固
(板上神人也不會擔心維修問題^^)
一片650元有30片
高雄可以面交
原廠網址 http://www.viatech.com.tw/tw/ini ... d/pc2500_mainboard/
規格如下
Form Factor Micro-ATX (4 layer)
225mm x 190mm
Processor 1.5GHz VIA C7-D Processor
400MHz VIA V4 Bus, NanoBGA2 package
Chipset North Bridge: VIA CN700 Digital Media IGP Chipset
South Bridge: VIA VT8237R Plus
System Memory 2 DDR2 DIMM slots (400/533MHz)
Up to 2GB memory size
VGA Integrated VIA UniChrome™ Pro IGP graphics with AGP interface
64/32/16MB shared system memory
Hardware MPEG-2 decoding acceleration
Expansion Slot 2 PCI slot
Onboard IDE/SATA 2 SATA connectors (optional)
2 UltraDMA/IDE 133/100/66 connectors
Onboard LAN 10/100Mbps Fast Ethernet VIA VT6103 PHY
Onboard Audio ALC655 6-channel AC'97 audio codec
Super I/O ITE Super I/O
Onboard I/O Connectors 2 USB 2.0 connectors (for 4 additional USB 2.0 ports)
1 Front-panel audio connector (mic and line out)
1 Floppy drive connector
1 CD Audio-in connector
1 SIR connector
2 Fan connectors: CPU/Sys FAN
1 ATX Power 20-pin connector
Back Panel I/O 4 USB 2.0 ports
1 RJ-45 LAN port
3 Audio jacks: line-out, line-in and mic-in
1 PS2 mouse port
1 PS2 keyboard port
1 LPT (parallel) port
1 COM (serial) port
1 VGA port (D-SUB 15-pin)
BIOS Award BIOS
512KB (4Mbit) Flash ROM
Operating System Support Microsoft® Windows® 2000/XP
Linux
System Monitoring & Management CPU temperature reading & voltage monitoring
Wake-on-LAN
Keyboard and timer power-on
System power management
AC power failure recovery
Operating Temperature 0 ~ 50 °C
Operating Humidity 10% ~ 90% (relative humidity; non-condensing)
MTBF 30,000 hours
發表於 2011-1-4 23:18:32 | 顯示全部樓層
這個價錢有沒有下降空間呢?
 樓主| 發表於 2011-1-5 21:23:15 | 顯示全部樓層
回復 2# jerrykan
不賺 600元給你不含運
GMT+8, 2026-11-5 01:01 AM , Processed in 0.018373 second(s), 5 queries , Gzip On, Redis On.
