查看: 33473|回覆: 27
剛挖到的新知識....SMD 電晶體代號規格
發表於 2011-5-25 14:37:11 | 顯示全部樓層 |閱讀模式
SMD電晶體二極體零件代號一覽表
說明:
SMT電晶體因零件很小,無法將零件名稱完全印上,所以用上面代號來表示例如:零件上印1A 表示是電晶體, 名稱是MMT3904 或2N3904 全部SMD電子零件皆如此編印,不要看外型皆一樣SOT23就認定它是電晶體雖然,大部份是電晶體,但也有的是二極體,也有Mosfet,有代號對照,以後維修就方便多了(1)diode代表二極體(2)transis代表電晶體(3)jfet代表場效晶體(4)mosfet代表高壓場效晶體(5) Dual*diode 裡面是兩顆二極體
零件表面印刷大部份是兩位數,但也有三位數             (網友善意回應歡迎惡意可免)
A1  diode BAW56W                    A4         diode BAV70W
A6  diode BAS16W                   A7         diode BAV99W
005  Dual*diode SSTPAD5          010       Dual*diode SSTPAD10
020  Dual diode SSTPAD20          050      Dual diode SSTPAD50
100  Dual diode SSTPAD100        200      diode SSTPAD200 Dual* Diode
15   transis MMBT3960 2N3960    1A      transis FMMT3904 2N3904
1B   transis BC846B / 2N2222      1C   transis MMBTA20 MPSA20
1E   transis BC847A BC547A        1F   transis BC847B BC547B
1G   transis C547C                      1J transis 2N2369
1K   transis BC848B                     1L   transis BC848C BC548C
1P   transis FMMT2222A               1T   transis MMBT3960A 2N3960A
1X   transis MMBT930                  1Y   transis MMBT3903 2N3903
2A   transis  2N3906                    2B   transis MMBT2907 2N2907
2C   transis BC549C                   2E   transis FMMTA93
2F   transis FMMT2907A             2J   transis MMBT3640 2N3640
2K   transis MMBT8598               2M   transis MMBT404
2N   transis MMBT404A              2T   transis MMBT4403 2N4403
2W   transis MMBT8599              2X   transis MMBT4401 2N4401
3A   transis  MMBTH24               3B   transis BC856B / FMMT918
3D   transis MMBTH81                3E   transis BC857A / MMBTH10 BC557A
3F   transis BC857B BC557B     3G   transis BC857C BC557C
3J   transis BC858A BC558A     3K   transis BC858B BC558B
3L   transis BC858C BC558C     449  transis FMMT449
489  transis FMMT489                4 91  transis FMMT491
493  transis FMMT493                4A   transis BC859A BC559A
4B   transis BC859B BC559B       4C   transis BC859C BC559C
4D  diode MMBV3401                  4E   transis FMMTA92
4F   Dual* Schottky diode           4J   transis FMMT38A
4M  Schottky diode                      4R   diode MMBV3700
4S   dSchottky diode                   4T   Schottky diode
500  Dual* diode SSTPAD500      549  transis FMMT549
589  transis FMMT589                  591  transis FMMT591
593  transis FMMT593                  5A   transis BC807-16
5AX  diode MMBD6050X               5B   diode MMBD6100
5B   transis / 2N4123                  5C   diode MMBD7000
5C   transis BC807-40                 5D   diode FMMD914 1N914
5DX  diode MMBD914X                 5E   transis BC808-16
5F  Schottky diode                       5F   transis BC808-25 BC328-25
5G  Dual* diode MMBD352           5G   transis BC808-40
5H Schottky diode                       6A   jfet MMBF4416
6B   jfet MMBF5484                     6B   transis BC817-25 BC337-25
6C   jfet MMBFU310
6C   transis BC817-40                6D   jfet MMBF5457
6E   jfet MMBF5460                     6E   transis BC818-16
6F   jfet MMBF4860                     6F    transis BC818-25
6G   jfet MMBF4393                    6G   transis BC818-40
6H   jfet MMBF5486                    6H   transis BC818-40 BC338-40
6J   jfet MMBF4391                     6K   jfet MMBF4932
6L   jfet MMBF5459                   6T     jfet MMBFJ310
6W  jfet MMBFJ175                    6Y     jfet MMBFJ177
6Z   mosfet* MMBF170              701        mosfet* 2N7001
702  mosfet* SN7002                 A1         diode BAW56
A1   sot323 BAW56W                     A1X   diode MBAW56 Dual* diode
A2X  Dua diode MMBD2836X           A3      diode BAT17 BA480
A3X  Dua diode MMBD2835Xl            A4   diode BAV70 BAW62 / 1N4148                    A4X  diode MBAV70 Dual* diode       A6   diode BAS16 BAW62
A61  diode 1N4148                           A7   diode BAV99 BAW62 / 1N4148
A7   sot323 BAV99W                        A7X   diode MBAV99 Dual* diode
AA   transis BCX51 BC636                AB     transis BCW60B
AC   transis BCW60C BC548B          AD    transis BCW60D
AE   transis BCX52                         AG      transis BCX70G
AH   transis BCX70H                       AJ    transis BCX70J
AK   transis BCX70K                        AL    transis MMBTA55
AM*  transis BSS64 2N3638           AS1    transis BST50 BSR50
B08  jfet SST6908 B09                   jfet     SST6909
B10   jfet SST6910                        B2     transis BSV52 PH2369 / BSX20
BA   transis BCX54 /                     BB   transis BCW61B
BC   transis BCW61C                   BD    transis BCW61D
BE   transis BCX55                       BG    transis BCX71G
BH   transis BCX56 BC639           BJ     transis BCX71J
BK   transis BCX71K                    BN     transis MMBT3638A
BR2  transis BSR31 2N4031        C1     transis BCW29
C11   jfet SST111                       C12     jfet SST112
C13   jfet SST113                        C2     transis BCW30 BC178B / BC558B
C41   jfet SST4091                     C42    jfet SST4092
C43   jfet SST4093                     C5     transis MMBA811C5
C59  jfet SST4859                       C6     transis MMBA811C6
C60  jfet SST4860                      C61    jfet SST4861
C7   transis MMBA811C7             C8      transis MMBA811C8
C91  jfet SST4391                       C92   jfet SST4392
C93  jfet SST4393                       CE     transis BSS79B
CEC  transis BC869 BC369         CF     transis BSS79C
CH   transis BSS82B / BSS80B      CJ     transis BSS80C
CM  transis BSS82C                     D1    transis BCW31 BC108A
D2   transis BCW32                      D3    transis BCW33 BC108C / BC548C
D6  transis MMBC1622D6             D7     transis MMBC1622D7
D8  transis BCF33 BC549C
DA  transis BCW67A                   DB     transis BCW67B
DE  transis BFN18                      DF     transis BCW68F
DG  transis BCW68G                   DH    transis BFN19
E1  transis BFS17 BFY90              EA    transis BCW65A
EB  transis BCW65B                     EC     transis / BCW67C
F1 transis MMBC1009F1             F3     transis MMBC1009F3
FA transis BFQ17 BFW16A         FE      transis BCV46
FG  transis BCV47                     GF      transis BFR92P
H1  transis BCW69                     H16    jfet SST4416
H2  transis BCW70 BC557B        I08      j fet SST108
I09  jfet SST109                         I10      jfet SST110
ITT  BA diode BAT42W           JA X       Dual* diode BAT42W
JD  diode BAW56                 JE           diode BAV99
JJ  diode BAV70                  JP            diode BAS19 BAV19
JS  diode BAS21 BAV21           K1        transis BCW71 BC547A
K2  transis BCW72 BC547B        K4      transis BCW71R
K7 transis BCV71                 L1            transis BSS65
L2  transis BSS70                 L3             transis MMBC1323L3
L4  transis MMBC1623L4          L42        diode BAT54A/T1 BAT85
L44  diode BAT54S/T1 BAT85       L4P     diode BAT54/T1 BAT85
L5   transis MMBC1623L5          L6         transis MMBC1623L6
L7 transis MMBC1623L7          M3            transis MMBA812M3
M4 jfet BSR56                         M4             transis MMBA812M4
M5 jfet BSR57                        M5               transis MMBA812M5
M6 jfet BSR58                        M6         transis BSR58 / MMBA812M6 2N4858
M7 transis MMBA812             M7           O2 transis BST82
P01 jfet SST201                    P02         jfet SST202
P03 jfet SST203                   P04             jfet SST204
P1 transis BFR92 BFR90        P2                transis BFR92A BFR90
P5 transis FMMT2369A         PRS             diode BAR64-05 Dual* diode
PSS Dual diode BAR64-04 *     Q3          transis MMBC1321Q3
Q4 transis MMBC1321Q4       Q5            transis MMBC1321Q5
R1 transis BFR93 BFR91       R2              transis BFR93A BFR91
S14 jfet SST5114               S15          jfet SST5115
S16 jfet SST5116              S1A          transis SMBT3904
S1D transis SMBTA42         S2         transis MMBA813S2
S2A transis SMBT3906        S2D       transis SMBTA92
S2F transis SMBT2907A       S3         transis MMBA813S3
S4 transis MMBA813S4        S70      jfet SST270
S71 jfet SST271               S74         jfet SST174
S75 jfet SST175                S76       jfet SST176
S77 jfet SST177               SA         Mosfet* BSS123
SS* mosfet* BSS138          T1         transis BCX17 BC327
T2 transis BCX18               T7         transis BSR15 2N2907
T8 transis BSR16 2N2907A      TFX    diode MBAL99
TV jfet MMBF112                    U1          transis BCX19 BC337
U2 transis BCX20                    U7        transis BSR13 2N2222
U8 transis BSR14 2N2222A     U92     transis BSR17A 2N3904
V01 mosfet* VN50300T          V02        mosfet* VN0605T
V04 mosfet* VN45350T         V0A        J mosfet* TP610T
V50 mosfet* VP0610T            Z08          jfet SST308
Z09 jfet SST309                    Z10             jfet SST310
Z2V transis FMMTA64
發表於 2011-5-25 21:55:48 | 顯示全部樓層
本帖最後由 MARCO 於 2011-5-25 09:56 PM 編輯
謝謝大大的分亨:)
發表於 2011-5-27 14:19:18 | 顯示全部樓層
本帖最後由 ck101 於 2011-5-27 02:19 PM 編輯
好東西,感謝分享
發表於 2011-5-27 20:47:15 | 顯示全部樓層
手上有台攝影機 , 上面有顆標示為TV的SMD燒毀 , 現在總算知道那是什麼東西了
謝謝 !
發表於 2011-5-28 12:57:19 | 顯示全部樓層
謝謝大大的分享
發表於 2011-5-31 19:50:36 | 顯示全部樓層
這真是新手福音~~~~~~
不用再望著貼片零件興嘆了~~~~n_143|
發表於 2011-5-31 20:05:19 | 顯示全部樓層
很好的資料, 給你加分鼓勵一下..
來來來, 小強伯抱一下.. ^_^
發表於 2011-6-10 18:14:19 | 顯示全部樓層
很棒的零件資料
收下備用了
感謝
發表於 2011-6-11 11:55:36 | 顯示全部樓層
這個對新手來說,幫助實在太大了。謝謝你的分享!
發表於 2011-6-11 16:15:57 | 顯示全部樓層
真的是寶耶!.對新手來說真是方便.不用每次看到代號還要查是二極體或是電晶體.謝謝.辛苦啦!............
發表於 2011-6-12 11:20:07 | 顯示全部樓層
備用中,3q
發表於 2011-6-12 11:34:55 | 顯示全部樓層
感謝分享
發表於 2011-6-12 12:19:46 | 顯示全部樓層
好資料! 感謝您的分享!
發表於 2011-6-12 17:08:52 | 顯示全部樓層
在網路上散佈不是屬於自己,而是別人,或別家公司的資料時,最好以連結網址的方式,最少在文中也要連結該文章的出處,否則那天出了問題,再來說什麼就來不及了,切記.
發表於 2011-6-14 08:51:27 | 顯示全部樓層
好東西
謝謝大大的分享
發表於 2011-6-14 13:44:04 | 顯示全部樓層
很實用的資料!讚!
發表於 2011-6-14 13:59:52 | 顯示全部樓層
好東西,感謝分享
發表於 2011-6-27 22:12:38 | 顯示全部樓層
這份資料實用, 謝謝分享
發表於 2011-6-28 12:05:14 | 顯示全部樓層
真的好實用的東西  收下囉  感恩^^
發表於 2011-7-4 19:59:13 | 顯示全部樓層
好資料! 感謝您的分享!
發表於 2011-7-4 21:41:41 | 顯示全部樓層
感謝大大分享寶貴的資料
發表於 2011-7-4 22:18:16 | 顯示全部樓層
感謝分享
發表於 2011-7-4 23:18:57 | 顯示全部樓層
好資料,謝謝分享
發表於 2011-11-27 00:44:07 | 顯示全部樓層
好東西,謝謝分享
發表於 2011-11-27 11:35:36 | 顯示全部樓層
很棒的零件資料謝謝大大的分享
發表於 2012-2-10 19:59:39 | 顯示全部樓層
好東西,感謝分享真是不簡單。
發表於 2012-2-13 21:41:38 | 顯示全部樓層
謝謝大大的分亨
發表於 2012-3-14 03:12:10 | 顯示全部樓層
資源無價~~感謝分享!!
GMT+8, 2026-11-27 01:42 AM , Processed in 0.035333 second(s), 5 queries , Gzip On, Redis On.
