查看: 52147|回覆: 51
用鍵盤打出μ,以及其他特殊符號
 火... [複製鏈接]
發表於 2010-8-30 00:29:51 | 顯示全部樓層 |閱讀模式
本帖最後由 rex560810 於 2010-11-10 12:37 AM 編輯
按住Alt不放,右邊數字鍵輸入41831,放掉Alt,就出現μ
以後電容單位可以打μF,不必再打uF啦
(希臘字母)
Α41796 Β41797 Γ41798 Δ41799 Ε41800 Ζ41801 Η41802 Θ41803 Ι41804 Κ41805 Λ41806 Μ41807 Ν41808 Ξ41809 Ο41810 Π41811
Ρ41812 Σ41813 Τ41814 Υ41815 Φ41816 Χ41817 Ψ41818 Ω41819
α41820 β41821 γ41822 δ41823 ε41824 ζ41825 η41826 θ41827 ι41828 κ41829 λ41830 μ41831 ν41832 ξ41833 ο41834 π41835
ρ41836 σ41837 τ41838 υ41839 φ41840 χ41841 ψ41842 ω41843
(羅馬數字)
Ⅰ41657 Ⅱ41658 Ⅲ41659 Ⅳ41660 Ⅴ41661 Ⅵ41662 Ⅶ41663 Ⅷ41664 Ⅸ41665 Ⅹ41666
(邊線符號;區塊繪圖元素)
∥41468 ∣41469 /41470
▁41570 ▂41571 ▃41572 ▄41573 ▅41574 ▆41575 ▇41576 █41577
▏41578 ▎41579 ▍41580 ▌41581 ▋41582 ▊41583 ▉41584
┼41585 ┴41586 ┬41587 ┤41588 ├41589
▔41590 ─41591 │41592 ▕41593
┌41594 ┐41595 └41596 ┘41597
╭41598 ╮41633 ╰41634 ╯41635
═41636 ╞41637 ╪41638 ╡41639
◢41640 ◣41641 ◥41642 ◤41643
╱41644 ╲41645 ╳41646
╔63965 ╦63966 ╗63967
╠63968 ╬63969 ╣63970
╚63971 ╩63972 ╝63973
╒63974 ╤63975 ╕63976
╞63977 ╪63978 ╡63979
╘63980 ╧63981 ╛63982
╓63983 ╥63984 ╖63985
╟63986 ╫63987 ╢63988
╙63989 ╨63990 ╜63991
║63992 ═63993
(貨幣金融;單位符號)
$41539 ¥41540 〒41541 ¢41542 £41543 %41544 @41545 ℃41546 ℉41547 ﹩41548 ﹪41549 ﹫41550
㏕41551 ㎜41552 ㎝41553 ㎞41554 ㏎41555 ㎡41556 ㎎41557 ㎏41558 ㏄41559 ° 41560
兙41561 兛41562 兞41563 兝41564 兡41565 兣41566 嗧41567 瓩41568 糎41569
(箭頭符號)
↑41460 ↓41461 ←41462 →41463 ↖41464 ↗41465 ↙41466 ↘41467
(特殊符號)
#41389 &41390 *41391 ※41392 § 41393  〃41394 ○41395 ●41396
△41397 ▲41398 ◎41399 ☆41400 ★41401 ◇41402 ◆41403 □41404 ■41405 ▽41406
▼41407 ㊣41408 ℅41409 ¯ 41410  ̄41411 _41412 ˍ41413 ﹉41414 ﹊41415 ﹍41416
﹎41417 ﹋41418 ﹌41419
﹟41420 ﹠41421 ﹡41422 +41423 -41424 ×41425 ÷41426 ±41427
√41428 <41429 >41430 =41431 ≦41432 ≧41433 ≠41434 ∞41435 ≒41436 ≡41437 ﹢41438 ﹣41439 ﹤41440 ﹥41441 ﹦41442 ~41443
∩41444 ∪41445 ⊥41446 ∠41447 ∟41448 ⊿41449 ㏒41450 ㏑41451 ∫41452 ∮41453 ∵41454 ∴41455 ♀41456 ♂41457 ⊕41458 ⊙41459
(標點符號)
,41281 、41282 。41283 .41284 ‧41285 ;41286 :41287 ?41288 !41289 ︰41290 …41291 ‥41292 ﹐41293 ﹑41294 ﹒41295 ‧41296 ﹔41297 ﹕41298 ﹖41299 ﹗41300
|41301 –41302 ︱41303 —41304 ︳41305 ╴41306 ︴41307 ﹏41308 (41309 )41310 ︵41311 ︶41312 {41313 }41314 ︷41315 ︸41316 〔41317 〕41318 ︹41319 ︺41320 【41321 】41322 ︻41323 ︼41324 《41325 》41326 ︽41327 ︾41328 〈41329 〉41330 ︿41331 ﹀41332 「41333 」41334 ﹁41335 ﹂41336 『41337 』41338 ﹃41339 ﹄41340 ﹙41341 ﹚41342 ﹛41377 ﹜41378 ﹝41379 ﹞41380 ‘41381 ’41382
“41383 ”41384 〝41385 〞41386 ‵41387 ′41388 #41389 &41390 *41391 ※41392 §41393 〃41394
發表於 2010-8-30 02:39:21 | 顯示全部樓層
試了一下不錯用
n_087| ╭∩╮(︶ε︶)╭∩╮
溜..............
 樓主| 發表於 2010-8-30 09:46:24 | 顯示全部樓層
棒賽偷窺╰*╯ ╰⊙╯╰∪╯╰O╯╰*╯
數字好像只能按右邊數字鍵
回復 2# 的帖子
有天份有天份:sam31
發表於 2010-8-30 11:47:48 | 顯示全部樓層
回復 3# 的帖子
剛剛試了一下......開出記事本,要來try ALT+41831,按住左ALT然後顫抖的手按下鍵盤左邊的4
嘎啊........所有的視窗畫面都不見了啊啊啊....n_130|
不小心跟dexpot這個多重桌面軟體的熱鍵重覆了....被切到第4個視窗   n_090|
這個輸入內碼的方法很好用,不過難的是....怎麼找出對應的數字  n_087|
發表於 2010-8-30 12:02:57 | 顯示全部樓層
喁用行列輸入法也有哦!
w9[sp][sp][sp]6
μ
其中sp 為空白鍵,換選字鍵三次。
發表於 2010-8-31 21:49:27 | 顯示全部樓層
這各方法真不錯喔~~
 樓主| 發表於 2010-11-10 00:43:20 | 顯示全部樓層
本帖最後由 rex560810 於 2010-11-10 12:44 AM 編輯
稍微重新編輯了一下
找到想用的符號
用複製的好像比較快
發表於 2010-11-10 02:12:58 | 顯示全部樓層
來個好用的小程式
特殊符號輸入程式.rar (11.55 KB, 下載次數: 225)
不用在記那麼多內碼了..0.0
發表於 2010-11-14 09:43:55 | 顯示全部樓層
使用NOTE BOOK沒有右邊數字鍵
可以也用上方數字鍵嗎
試不出來耶
 樓主| 發表於 2010-11-14 10:05:40 | 顯示全部樓層
回復 9# danto
筆電用白色數字鍵好像不行
要用藍色數字鍵
方法:藍色Fn鍵+藍色NumLk鍵
此時藍色數字鍵就可以開始用了
用完記得再按一次:藍色Fn鍵+藍色NumLk鍵
讓鍵盤恢復正常
發表於 2010-11-14 14:01:58 | 顯示全部樓層
回復 1# rex560810
    雷大有全部背起來嗎?
發表於 2010-11-14 15:05:31 | 顯示全部樓層
好厲害的μ...常用的給他記起來...
多謝!!
發表於 2010-11-14 15:25:44 | 顯示全部樓層
好酷喔...我要偷學~
 樓主| 發表於 2010-11-14 20:59:05 | 顯示全部樓層
回復 11# atun
光41831偶就背好久了......
發表於 2010-11-14 21:33:51 | 顯示全部樓層
1000 μF
I got it. 41831
 樓主| 發表於 2010-11-14 23:58:13 | 顯示全部樓層
回復 13# 好奇
比中指要用組合的
看2樓就知道了
發表於 2010-11-15 08:22:35 | 顯示全部樓層
回復 1# rex560810
    μ我用2003 WORD,打不出來μ,而在這裡可以?
發表於 2010-11-15 10:43:32 | 顯示全部樓層
本帖最後由 jimpo 於 2010-11-15 10:48 AM 編輯
哈哈哈,我的NB打不出那些字組,用 ALT + 數字 ==> 打不出來
有 NB的人請試試看,我沒有右邊數字鍵盤,我用的是上方的數字鍵
更新:確實要開啟 NUM LK  亮燈,才能用藍色數鍵盤組,啊,不好用
 樓主| 發表於 2010-11-15 10:50:15 | 顯示全部樓層
回復 17# atun
Word 2003 中文僅接受 16 進位的輸入方式(Unicode 或 Big5)
10 進位的 Alt +41831無法輸入
不過Excel 卻可以,真是奇怪?
那Word只好用 "插入" "符號"
或者尼要用下面的方法
1. 切換到新注音輸入法
2. 切換成半形(shift+space)
3. 按鍵盤左上方的`鍵,接著再按U鍵
4. 輸入代碼就會出現符號了,代碼要用字母鍵盤的數字打
例如:輸入`U03bc就會出現μ
†=2020     ‡=2021     ₪=20AA     ™=2122     ↖=2196
↗=2197     ↘=2198     ↙=2199     ∞=221E     ∥=2225
∩=2229     ∪=222A     ∫=222B     ∮=222E     ∵=2235
∴=2234     ≒=2252     ≠=2260     ≡=2261     ≦=2266
≧=2267     ⊕=2295     ⊙=2299     ⊥=22A5     ⊿=22BF
⌇=2307     ┿=253F     ═=2550     ╞=255E     ╟=255F
╠=2560     ╡=2561     ╢=2562     ╣=2563     ╪=256A
╬=256C     ╭=256D     ╮=256E     ╯=256F    ╰=2570
╳=2573     □=25A1     ■=25A0     ▲=25B2     △=25B3
▼=25BC     ▽=25BD     ◆=25C6     ◇=25C7     ○=25CB
◎=25CE     ●=25CF     ◢=25E2     ◣=25E3     ◤=25E4
◥=25E5     ★=2605     ☆=2606     ☉=2609     ♀=2640
♁=2641     ♂=2642     〒=3012     ㊣=32A3     ︵=FE35
︶=FE36     ︹=FE39     ︺=FE3A     ︽=FE3D     ︿=FE3F
¢=FFE0     £=FFE1     ¥=FFE5     №=2116     ♪=266A
♭=266D     〃=3003     Σ=03A3     Υ=03A5     Ψ=03A8
Ω=03A9     α=03b1      β=03b2      γ=03b3      δ=03b4
ε=03b5      ζ=03b6      η=03b7      θ=03b8      ι=03b9
κ=03ba     λ=03bb      μ=03bc      ν=03bd      ξ=03be
ο=03bf      π=03c0      ρ=03c1      σ=03c3      τ=03c4
υ=03c5      φ=03c6      χ=03c7      ψ=03c8      ω=03c9
℃=2103
℅=2105     ℉=2109     ¤=00A4     §=00A7     ±=00B1
‰=2030     ▒=2592     ▣=25A3     ▤=25A4     ▥=25A5
▦=25A6     ▧=25A7     ▩=25A9     ▶=25B6     ▷=25B7
◀=25C0     ◁=25C1     ◈=25C8     ◐=25D0     ◑=25D1
☎=260E     ☏=260F     ☜=261C     ☞=261E     ♤=2664
♥=2665     ♡=2661     ♨=2668     ♩=2669     ♫=266B
♬=266C     ☺=263A     ☻=236B     ♦=2666     ☼=263C
♣=2663     ♠=2660     ♧=2667     ①=2460     ②=2461
③=2462     ④=2463     ⑤=2464     ⑥=2465     ⑦=2466
⑧=2467     ⑨=2468     ⑩=2469     ⑪=246A     ⑫=246B
⑬=246C     ⑭=246D     ⑮=246E     ⑯=246F     ⑰=2470
⑱=2471     ⑲=2472     ⑳=2473     ⓐ=24D0     ⓑ=24D1
ⓒ=24D2     ⓓ=24D3     ⓔ=24D4     ⓕ=24D5     ⓖ=24D6
ⓗ=24D7     ⓘ=24D8     ⓙ=24D9     ⓚ=24DA     ⓛ=24DB
ⓜ=24DC     ⓝ=24DD     ⓞ=24DE     ⓟ=24DF     ⓠ=24E0
ⓡ=24E1     ⓢ=24E2     ⓣ=24E3     ⓤ=24E4     ⓥ=24E5
ⓦ=24E6     ⓧ=24E7     ⓨ=24E8     ⓩ=24E9
發表於 2010-11-15 13:32:02 | 顯示全部樓層
回復  atun
不 ...
rex560810 發表於 2010-11-15 10:50 AM http://bbs.pigoo.com/images/common/back.gif
    喔喔!這個就更厲害了!:sam31
發表於 2010-11-24 16:59:21 | 顯示全部樓層
不錯用.謝謝娜...
發表於 2011-1-26 15:01:16 | 顯示全部樓層
本帖最後由 AGC 於 2011-1-26 03:03 PM 編輯
原PO貼的是ANSI碼。
19F貼的是萬國碼,為了方便及統一,使用後者較不會有問題出現。
分別為 U+3393 U+3394 U+33BC U+33C8 U+33C6
 樓主| 發表於 2011-1-26 18:36:44 | 顯示全部樓層
回復 22# AGC
偶現在偶而要用特殊符號時
都找自己發的這篇
然後
--->複製 --->貼上 :sam16 :sam16 :sam16
發表於 2011-1-26 22:48:41 | 顯示全部樓層
去抓 Babel Map ( http://www.babelstone.co.uk/Software/BabelMap.html )回來,要什符號,就有什麼 XD
Unicode 6.0出來了,可惜找不到相關的字型可用
發表於 2011-1-29 14:47:28 | 顯示全部樓層
來個好用的小程式
不用在記那麼多內碼了..0.0
akgkaylin 發表於 2010-11-10 02:12 AM http://bbs.pigoo.com/images/common/back.gif
    這個比較實在感謝分享呵呵,那我真的不用打uf了呵呵
發表於 2011-1-31 15:03:06 | 顯示全部樓層
好神奇的方法,謝謝分享
發表於 2011-2-1 12:19:28 | 顯示全部樓層
以我來說,我比較常用 µ (U+00B5) 而不用全形字,以配合下個一英文字母
發表於 2011-2-1 19:40:04 | 顯示全部樓層
大概就背這兩個就夠了吧?
μ 41831
Ω 41819
發表於 2011-2-24 23:19:29 | 顯示全部樓層
發表於 2011-2-25 09:08:26 | 顯示全部樓層
真的又長智慧了
GMT+8, 2026-11-5 06:22 PM , Processed in 0.419476 second(s), 7 queries , Gzip On, Redis On.
