樓主: iostreamx
電瓶再生器
發表於 2010-5-5 16:07:26 | 顯示全部樓層
無加水電瓶也可以嗎
回復
發表於 2010-11-7 01:44:49 | 顯示全部樓層
應該有效吧!
http://www.youtube.com/watch?v=r ... ure=player_embedded
最近電池老化,或許可以試試看!
回復
發表於 2010-11-7 02:53:24 | 顯示全部樓層
很棒的電路,改天再試!先收下了。3Q
回復
發表於 2010-11-7 08:31:53 | 顯示全部樓層
我想這只是''治標不治本的方法.....治本的方法呢...國外跟國內都有回收電池(大型機具的電池) 電池再生的廠 ...
levis123123 發表於 2010-4-2 10:59 AM http://bbs.pigoo.com/images/common/back.gif
雄大,之前 Slimboy 大大提到電瓶水活化液(醋酸氨),後來我去買了一罐來試試,電瓶隔水加熱到60度,加入醋酸氨飽和溶液,發現並沒有起泡的現象(清除極板上的雜質),請問您知道要如何使用嗎?另外,您所說的氯化氨要如何使用呢?加熱還是充電中加入?需要調製飽和溶液嗎?感謝~
回復
發表於 2010-11-7 10:31:40 | 顯示全部樓層
回復 34# py924
電瓶活化水我是沒用過
添加氯化氨我也好像沒提到過
我只有對密閉式免保養電池加過RO水
之後再充飽電後再放電,重複幾次後
如果無法活話就丟回收場放棄了
回復
發表於 2010-11-7 11:09:26 | 顯示全部樓層
這樣喔~因為我總認為化學修復比物理修復來得有效率,只是目前的方法都不得而知。網路上也是一堆用硫酸鎂讓電瓶回春的方法,目前暫無時間作實驗。除了硫酸鎂以外,做讓我注目的是EDTA,牙醫做根管治療也常用EDTA(螯合劑),請看此網頁的其中一段。
出自:http://www.deathstar.org/~flash/edta.html
You can prolong the life of batteries by an additive that prevents sulfation. Supposed to be particularly good for batteries subjected to infrequent use, short trips, or inefficient charging system. Once-only treatment lasts for the life of the rejuvenated battery.
Obtain some EDTA (tetrasodium ethylenediaminetetraacetate or simply tetrasodium EDTA) from a chemical or lab supply place. This is a chelating agent and (I THINK) used on folks that are going to get an MRI scan. Four (4) grams are divided into approximately equal portions and added to all the cells of a motorcycle battery. Four grams are added to each cell in an automotive battery. Agitate battery frequently for a few days (normal use will do). Finally, give the battery a thorough charge.
The article sez that the method works on batteries that work but don't work "well enough" anymore. It says that the earlier in its life you give it the treatment, the longer it will last. It claims that a marginal battery can be restored to useful condition for a period of time "quite often by many years."
回復
GMT+8, 2026-2-13 09:30 AM , Processed in 0.018083 second(s), 2 queries , Gzip On, Redis On.
快速回復 返回頂部 返回列表
