查看: 2101|回覆: 2
[Android] Google的新人工智慧助手Google Gemini, new AI assistant
發表於 2024-11-28 14:40:00 | 顯示全部樓層 |閱讀模式
本帖最後由 bangder 於 2024-11-28 02:45 PM 編輯
Google Gemini
Meet Gemini, your new AI assistant
Welcome to Gemini, your upgraded AI assistant from Google that can help you supercharge your creativity and productivity. Gemini can not only provide the hands-free help that you love from Google Assistant, but can go far beyond in conversationality and richness of the tasks it can help with. With Gemini on your phone, you can now have a natural, free-flowing voice conversation through Gemini Live1, and get help writing, creating, learning, and more. Gemini will now serve as your Android device’s primary assistant. Learn more about what you can do with Gemini.
If you wish to switch your device’s primary assistant to Google Assistant, you can do that in Settings. How to switch.
How Gemini handles data and works with other services
Gemini uses info from your devices and services to help you
Gemini uses info from your devices and services to provide more customized and context-aware assistance. Gemini accesses certain system permissions and data (including through Google Assistant), like call and message logs, contacts (to help you keep in touch), and screen content (to help you act on it).
Gemini works with Google Assistant
Gemini gets help from Google Assistant for certain actions. When that happens, relevant Assistant settings such as Personal Results apply. When Gemini handles actions through Extensions, those Google Assistant settings won’t apply. Learn more.
Gemini Extensions
With Extensions, Gemini can respond with real-time info from other services, like Google Maps and YouTube. You can also choose to connect services like Google Workspace and YouTube Music. If Gemini finds an Extension that can help, it will send information from your conversation, and other relevant information, to that Extension to help it generate a better response. You can manage your Gemini Extensions settings. Learn more.
Things to know when speaking to Gemini
If “Hey Google” & Voice Match (powered by Google Assistant) are on in Settings, you can talk to your assistant hands-free. Gemini may activate when you didn’t intend it to, for example, if it detects a noise like “Hey Google,” or if you accidentally activate it by touch. If Gemini responds, it will treat your input like a normal activation.
Gemini responses on lock screen
Gemini helps you with answers and actions even when your device is locked. To protect your privacy, Gemini will still require you to unlock for some actions, for example when responses contain your personal content from apps (such as calendar events). You can change your Gemini on lock screen settings. Learn more.
Gemini activity and your choices
When you use Gemini, Google collects your activity, like your chats and location info. This data is stored in your Google Account and used to improve Google AI and services with help from trained reviewers. You can manage your Gemini Apps Activity settings. Don’t enter info you wouldn’t want reviewed or used. Learn more.
Note: Google Terms apply to Gemini Apps. Google will process your data as described in the Google Privacy Policy and the Gemini Apps Privacy Notice. Gemini can make mistakes, including about people, so double-check it.
中文翻譯
來認識 Gemini,你的新人工智慧助手
歡迎使用 Gemini,您的 Google 升級版人工智慧助手,可以幫助您增強創造力和生產力。 Gemini 不僅可以透過 Google Assistant 提供您喜歡的免持協助,而且在會話性和任務豐富性方面也遠遠超出了它所能提供的幫助。有了手機上的 Gemini,您現在可以透過 Gemini Live1 進行自然、流暢的語音對話,並獲得寫作、創作、學習等方面的幫助。 Gemini 現在將成為您 Android 裝置的主要助理。詳細了解您可以使用 Gemini 做什麼。
如果您希望將裝置的主要助理切換為 Google Assistant,可以在「設定」中執行此操作。如何切換。
Gemini 如何處理資料並與其他服務搭配使用
Gemini 使用您的裝置和服務中的資訊來幫助您
Gemini 使用來自您的裝置和服務的資訊來提供更多客製化和情境感知的幫助。 Gemini 存取某些系統權限和資料(包括透過 Google Assistant),例如通話和訊息日誌、聯絡人(以協助您保持聯繫)和螢幕內容(以協助您採取行動)。
Gemini 與 Google Assistant 搭配使用
Gemini 可以透過 Google Assistant 取得某些操作的協助。發生這種情況時,相關的 Google 助理設定(例如個人搜尋結果)將適用。當 Gemini 透過擴充功能處理操作時,這些 Google Assistant 設定將不適用。了解更多。
雙子座擴展
透過擴展,Gemini 可以透過其他服務(例如 Google 地圖和 YouTube)的即時資訊來回應。您也可以選擇連接 Google Workspace 和 YouTube Music 等服務。如果 Gemini 找到可以提供幫助的擴充程序,它會將您的對話中的信息以及其他相關資訊發送到該擴充程序,以幫助其產生更好的回應。您可以管理您的 Gemini 擴充設定。了解更多。
與雙子座交談時要注意的事情
如果「Hey Google」和 Voice Match(由 Google Assistant 提供支援)在「設定」中開啟,您可以免持與助理通話。 Gemini 可能會在您無意時激活,例如,如果它檢測到“嘿 Google”之類的噪音,或者您不小心通過觸摸激活了它。如果 Gemini 回應,它會將您的輸入視為正常啟動。
雙子座在鎖定畫面上的反應
即使您的裝置處於鎖定狀態,Gemini 也可以幫助您找到答案並採取行動。為了保護您的隱私,Gemini 仍會要求您解鎖某些操作,例如回覆包含您來自應用程式的個人內容(例如日曆事件)時。您可以變更 Gemini 的鎖定畫面設定。了解更多。
雙子座的活動和你的選擇
當您使用 Gemini 時,Google 會收集您的活動,例如您的聊天記錄和位置資訊。這些資料儲存在您的 Google 帳戶中,並在訓練有素的審核人員的幫助下用於改進 Google AI 和服務。您可以管理您的 Gemini 應用程式活動設定。不要輸入您不想查看或使用的資訊。了解更多。
注意:Google 條款適用於 Gemini Apps。 Google 將按照 Google 隱私權政策和 Gemini Apps 隱私權聲明中的說明處理您的資料。雙子座可能會犯錯誤,包括關於人的錯誤,所以要仔細檢查。
補充內容 (2024-11-28 11:55 PM):
前天 我的手機竟然自動裝了這APP
當下我想說是不是不明的惡意程式
想要移除它 竟然無法移除指跳出要我設定
當下也沒多想 就去睡覺了
今天上英文....克
補充內容 (2024-11-28 11:58 PM):
今天上英文課 老師要我們安裝
設定用英文介面
老師當下就玩起來了
這比SIRI還厲害
發表於 2024-12-2 19:58:18 | 顯示全部樓層
想要移除它 竟然無法移除指跳出要我設定
  "Gemini" 與 "Google 助理" 的圖示是共存的.
  若想移除 Gemini, 先啟動 "Google 助理" 前往 "設定" 切換, 選擇你的 Google 數位助理, 點選回 "Google 助理" 後應可移除 Gemini 了.
 樓主| 發表於 2024-12-3 05:10:43 | 顯示全部樓層
本帖最後由 bangder 於 2024-12-3 05:14 AM 編輯
nessie 發表於 2024-12-2 07:58 PM
  若想移除 Gemini, 先啟動 "Google 助理" 前往 "設定" 切 ...
謝謝 了解
我會留著不會移除
畢竟他結合AI 還蠻好用的
只是要設定英文介面
因為他目前設計為給歐美人士使用(文化)
我正好利用它來練習英文口語
GMT+8, 2026-11-19 01:57 AM , Processed in 0.020726 second(s), 5 queries , Gzip On, Redis On.
