查看: 4859|回覆: 0
X86突破4G限制!(不穩)
發表於 2020-3-1 11:16:32 | 顯示全部樓層 |閱讀模式
本帖最後由 bluse 於 2020-3-1 11:20 AM 編輯
https://wj32.org/wp/2013/10/25/pae-patch-updated-for-windows-8-1/
cmd模式必須系統管理員權限執行
PatchPae (v2) by wj32.
Tested on: Windows Vista SP2, Windows 7 SP0, Windows 7 SP1, Windows 8, Windows 8.1, Windows 10 (build 10586)
== Installation ==
1. Open an elevated Command Prompt window.
2. cd C:\Windows\system32.
Make sure the current directory is in fact system32.
[[ For Windows 8, Windows 8.1 and Windows 10: ]]
3. C:\WherePatchPaeIs\PatchPae2.exe -type kernel -o ntoskrnx.exe ntoskrnl.exe
This will patch the kernel to enable a maximum of 128GB of RAM.
[[ For Windows Vista and Windows 7: ]]
3. C:\WherePatchPaeIs\PatchPae2.exe -type kernel -o ntkrnlpx.exe ntkrnlpa.exe
4. C:\WherePatchPaeIs\PatchPae2.exe -type loader -o winloadp.exe winload.exe
This will patch the loader to disable signature verification.
5. bcdedit /copy {current} /d "Windows (PAE Patched)"
This will create a new boot entry. A message should appear:
The entry was successfully copied to {xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx}.
{xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx}系統自動產生
6. bcdedit /set {xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx} kernel ntoskrnx.exe
This will set our boot entry to load our patched kernel.
6. bcdedit /set {xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx} kernel ntkrnlpx.exe
7. bcdedit /set {xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx} path \Windows\system32\winloadp.exe
This will set our loader to be our patched loader.
8. bcdedit /set {xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx} nointegritychecks 1
This will disable verification of the loader.
9. bcdedit /set {bootmgr} default {xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx}
This will set our boot entry to be the default.
10. bcdedit /set {bootmgr} timeout 2
This will set the timeout to be shorter.
Note: you can change this timeout to whatever you like.
11. Restart the computer and enjoy.
執行msconfig更改開機選單留下PAE其餘刪除
== Removal ==
To remove the patch:
* Run msconfig, click Boot, highlight the entry named "Windows (PAE Patched)", and click Delete.
* Delete the files ntoskrnx.exe (or ntkrnlpx.exe) and winloadp.exe from C:\Windows\system32.
== Updates ==
When Windows Update installs new updates on your computer, you should run Step 3 again to ensure
that you have the latest version of the kernel.
X86系統只能ˋ抓到2G!4G可試試看在掛網機或輕度使用機!之前網頁開太多就掛了!換灌Win7 X64
GMT+8, 2026-10-11 12:21 PM , Processed in 0.019888 second(s), 8 queries , Gzip On, Redis On.
