12
返回列表 發新帖
樓主: chaochin
led閃爍電路,卻不動作,請教高手指導修正。
發表於 2017-9-12 04:59:57 | 顯示全部樓層
本文章最後由 jungping 於 2017-9-12 05:03 AM 編輯
ericchou 發表於 2017-9-11 11:40 PM
p.s. 電阻的表示,4700000就可以,但我改成4.7m時,模擬就沒有結果。
我有試過,打入4.7M的話,雖然會接受,但是結果卻是顯示4.7m,並且看起來就是代表milli-的意思。所以還是不行。
不過,若是打入4700k的話,是沒問題的。
我才剛學,若是有錯,請指正。
發表於 2017-9-12 07:45:54 來自手機 | 顯示全部樓層
4.7Meg 試試看
發表於 2017-9-12 07:54:09 | 顯示全部樓層
試過了。4.7Meg真的可以!
發表於 2017-9-12 18:23:53 | 顯示全部樓層
發表於 2017-9-12 19:47:25 | 顯示全部樓層
小喇叭大
n_116|
順便查了軟體說明檔中
其它標示單位如下
Numbers can be expressed not only in scientific notation; e.g., 1e12; but also using engineering multipliers. That is, 1000.0 or 1e3 can also be written as 1K. Below is a table of understood multipliers:
SuffixMultiplier
T 1e12
G 1e9
Meg 1e6
K 1e3
mil 25.4e-6
m 1e-3
u(or μ)1e-6
n 1e-9
p 1e-12
f 1e-15
The suffixes are not case sensitive. Unrecognized letters immediately following a number or engineering multiplier are ignored. Hence, 10, 10V, 10Volts, and 10Hz all represent the same number, and M, MA, MSec, and MMhos all represent the same scale factor(.001). A common error is to draft a resistor with value of 1M, thinking of a one Megaohm resistor, however, 1M is interpreted as a one milliohm resistor. This is necessary for compatibility with standard SPICE practice.
LTspice will accept numbers written in the form 6K34 to mean 6.34K. This works for any of the multipliers above. It can be turned off by going to Tools=>Control Panel=>SPICE and unchecking "Accept 3K4 as 3.4K".
Nodes names may be arbitrary character strings. Global circuit common node(ground) is "0", though "GND" is special synonym. Note that since nodes are character strings, "0" and "00" are distinct nodes.
Throughout the following sections of the manual, angle brackets are placed around data fields that need to be filled with specific information; for example, "<srcname>" would be the name of some specific source. Square brackets indicate that the enclosed data field is optional.
 樓主| 發表於 2017-9-19 20:58:36 | 顯示全部樓層
各位大大好:
今天又提起來,原先電路修改如下,led居然閃爍了。真令人高興。
最主要的有R1和R2改成510K,R3改5K,而最關鍵的是,LED前的電阻拿掉後,LED才閃爍。
影片        drive.google.com/drive/folders/0BwFwRzihUqheMW9GVnllWEdqNzQ
電路圖
今天會動起來的原因是,是到電子材料行買洞洞板,想說買菜送蔥,就請老板指導一下,
老板看了電路圖,說要詳細計算啦,不過,先加大電容試看看。
回去便加電容從2.2加到33μ,起初還是會亮不閃,東調西調,居然變成通電後延遲了幾秒才亮,
期待LED會暗下來,但沒有,也就是可斷定有充電,沒放電吧!
因為書上原圖燈之前是沒有電阻的,於是就拿掉LED前面的電阻,就這樣閃爍動作起來了。
另外,再試R1、R2接回4.7K,R3用1K,結果是一個怪怪的閃爍現象,燈有一點點閃爍的樣子,但無法全滅,漸漸亮度變暗一點。
我猜LED受損。改接回510K等等,換顆新LED,是正常的,拿受損的LED,會閃爍,但亮度只有一點點,至此確定,R1不能用4.7K等等,
會損壞LED。
P.S.把會閃爍的電路圖弄上LTSPICE跑看看,電容的電壓還是水平的,沒看到起伏的充放電波形。可是實際電路會閃爍,表示電容有充放電呀!附上電路圖檔案
 樓主| 發表於 2017-9-19 21:01:27 | 顯示全部樓層
本文章最後由 chaochin 於 2017-9-19 09:04 PM 編輯
chaochin 發表於 2017-9-19 08:58 PM
各位大大好:
最主要的有R1和R2改成510K,R ...
SORRY
因為沒有權限發表URL,來回幾次,圖片和電路圖就不見了。
補電路圖和附件。        google drive網址前,請加https://
Draft1-3-final.zip
596 Bytes, 下載次數: 10
發表於 2017-9-19 23:05:05 | 顯示全部樓層
chaochin 發表於 2017-9-19 09:01 PM
SORRY
要不要試個更好玩的。
HB-LED閃光標燈賦予開關穩壓器新的用途.pdf (215.42 KB, 下載次數: 17)
發表於 2017-9-20 10:13:09 | 顯示全部樓層
LED 若無適當限流就得限制點亮時間。Elektor Magazine 2008年07-08月號曾刊載一個 Smooth Flasher 小品電路,基本上它是一個極低頻的"RC相移振盪器"如下圖,內文說明請參考:Smooth Flasher(Elektornonlinear.ir2008-07_08).pdf
http://bbs.pigoo.com/forum.php?mod=image&aid=249509&size=300x300&key=538a245ed61999d5&nocache=yes&type=fixnone
 樓主| 發表於 2017-9-20 21:09:01 | 顯示全部樓層
upchome 發表於 2017-9-19 11:05 PM
要不要試個更好玩的。
這,太難了。我只能從簡單的開始。還是謝謝你熱心的提供,先存起來囉!
發表於 2017-9-20 21:34:40 | 顯示全部樓層
SORRY
你確定檔案沒有錯嗎?
我用win 7,LTspice最新版的不動作.
 樓主| 發表於 2017-9-20 21:41:08 | 顯示全部樓層
skyboat0520 發表於 2017-9-20 10:13 AM
LED 若無適當限流就得限制點亮時間。Elektor Magazine 2008年07-08月號曾刊載一個 Smooth Flasher 小品電路 ...
謝謝你,找時間裝裝看。
原資料只簡單交待幾句,
初學研究了半天,不能了解R4和C1的功能是什麼?
GMT+8, 2024-4-19 08:14 PM , Processed in 0.064493 second(s), 17 queries , Gzip On.
