查看: 3804|回復: 1
Windows MultiPoint Server 2011
發表於 2012-3-19 14:49:31 | 顯示全部樓層 |閱讀模式
Description:
Microsoft Windows MultiPoint Server 2011 Premium is a special version of the Microsoft Windows Server 2008 R2 SP1 operating system that allows multiple users to simultaneously share one computer. Each user station, typically consisting of a monitor, keyboard, and mouse connected to a station hub, provides an independent Microsoft Windows desktop environment. The station hubs connect to the single host computer through USB or video cables and use the host computer's processing capabilities.
Microsoft Windows MultiPoint Server 2011 Premium Edition supports up to 20 simultaneously connected user stations. The host computer also can be used as a station to support one additional user. Microsoft Windows MultiPoint Server 2011 Premium Edition also supports joining an Active Directory domain if needed, providing users with access to network services.
Microsoft Windows MultiPoint Server 2011 can be useful for organisations or libraries with computer labs, classrooms, or other collaborative environments where using just one computer for several users can save energy, simplify maintenance, and lower expenses. The ability to share a monitor in split screen view between two independent users and to connect older machines as stations over a local area network (LAN) provides further cost- and energy-saving options.
Microsoft Windows MultiPoint Server includes MultiPoint Manager, which allows the primary user to monitor and manage Microsoft Windows MultiPoint Server 2011 user stations. Primary users can create accounts for an unlimited number of standard users, who can access their customized desktop and settings by logging into any station. Primary users also can view full screens of individual users or thumbnail screens of all active users, allowing them to monitor user activity without leaving their station. They can suspend all stations at once or broadcast the desktop of their own or any user's computer to all other connected user stations.
Other capabilities include the following:
Software programs installed on the host computer can be accessed from any connected station, without separately installing the software for each user. (Note that Microsoft Office and other Microsoft programs available through Volume Licencing require a separate licence for each user station in a Microsoft Windows MultiPoint Server environment. Other software manufacturers may have their own licencing requirements for shared computing environments.)
Public Documents folders allow users to share information and collaborate on projects, while users' private folders can be accessed only by the user or the administrator.
Traditional desktops, laptops, and thin clients also can act as stations by connecting to the host computer using Remote Desktop Protocol (RDP) over a local area network (LAN). This allows an organisation to use existing and possibly older computers as stations without removing those computers' ability to operate independently (devices connecting over LAN must be licenced in the same manner as other user stations).
Licencing: This product includes a Microsoft Windows MultiPoint Server 2011 Premium Edition server licence. Each user station that connects to Microsoft Windows MultiPoint Server must have two types of client access licences (CALs): a Microsoft Windows MultiPoint Server CAL and a Microsoft Windows Server CAL. These two CALs, licenced per device (a user station), are available as a single donation through DonorTec (see Related Products below). If the host computer is used as a user station and not just for administration, organisations must acquire both a Microsoft Windows MultiPoint Server CAL and a Microsoft Windows Server CAL for it as well.
Individual Microsoft Windows MultiPoint Server device CALs are also available through DonorTec for users with valid Microsoft Windows Server CALs. Microsoft Windows MultiPoint Server user CALs, as opposed to Microsoft Windows MultiPoint Server device CALs, are not available through DonorTec since this kind of licencing would be more costly in a typical Microsoft Windows MultiPoint Server setup than licencing per device. For example, a setup with 10 user stations would require just 10 device CALs for any number of users. If licenced per user, the same setup would require each user to have a separate licence.
At the Microsoft Volume Licencing Service Center, the product key for Microsoft Windows MultiPoint Server 2011 will be listed as Microsoft Windows Server 2008 R2.
64-Bit Only: Microsoft Windows MultiPoint Server 2011 requires a 64-bit processor with at least two cores.
Requirements:
For host computer:
2-GHz (or higher) dual-core x64 processor
1 GB RAM for Microsoft Windows MultiPoint Server 2011 and the first two stations; 512 MB for each additional station
32 GB available hard-disk space
DVD drive
UPDATE for Microsoft Windows MultiPoint Server 2011
Update Rollup 1.1 for Microsoft Windows MultiPoint Server 2011 (KB2626067)
Update for Microsoft Windows MultiPoint Server 2011 (KB2530453)
Update for Microsoft Windows MultiPoint Server 2011 (KB2542222)
Language Packs
官網提供的正體中文版
發表於 2012-3-20 00:44:36 | 顯示全部樓層
GMT+8, 2024-4-25 03:55 PM , Processed in 0.060694 second(s), 21 queries , Gzip On.
