查看: 4071|回復: 1
Hard Disk Sentinel Professional v3.60 硬碟監控繁簡體中文專業版
發表於 2011-6-7 14:14:53 | 顯示全部樓層 |閱讀模式
本帖最後由 windata 於 2011-6-7 10:05 PM 編輯
【檔案名稱】:Hard Disk Sentinel Pro v3.60 + Key
【檔案大小】:15.91 MB
【檔案格式】:EXE
【軟體語言】:多國語言(繁簡體中文)
【內容說明】:
Hard Disk Sentinel 它使用 SMART 技術監控硬碟健康、性能,及溫度等重要參數。
Hard Disk Sentinel 是一個多作業系統硬碟/ SSD的監測和分析應用。它的目標是尋找,測試,診斷和修復磁碟機的問題,報告和顯示SSD和硬碟健康,性能降級和失敗。
Hard Disk Sentinel 提供完整的文本描述,提示和顯示/報告最全面的資訊對硬碟和固態磁片在計算器內部或外部許多不同的警報和報告選項。
What's New :3.60 (9/8/2011)
改進和新的特點:
•File -> Open status of offline disk(s)
Load and display previously saved disk status and statistics for any hard disk / SSD previously connected. (registered version only)
•File -> Windows Volume/RAID Information
Display Windows Logical Disk Management information including software RAID status
•Report -> Save Authentic Disk Report
Save report about selected hard disk(s) and protect the report to prevent unauthorized change (ideal for disk resellers / maintenance) (registered version only)
•Report -> Verify Authentic Disk Report
Verify if the previously saved authentic disk report is valid (registered version only)
•detect volume information (partition style, type, alignment, cluster size)
•display more details in Random seek Test window
•detect and display if TRIM is supported and enabled in the OS for an SSD
•improved text description for HDD/SSD specific attributes
改進硬件的支持:
•better detection on LSI RAID controllers
•improved power on time detection
•improved real time performance display
•improved 3ware controller support: detection of SATA, SAS disks
•improved AMD RAID controller support: detection of one disk per RAID arrays (limited by the RAID controller) when the latest driver is used from Driver Zone
•improved Intel RAID controller support
•improved Marvell 6G SATA controller support
•improved acoustic management / advanced power management setting
•proper detection of new SSD controllers (Marvell, Sandforce, Intel, JMicron, etc.)
•proper detection of new SSD models (OCZ Vertex3, Intel 320, Intel 510, etc.)
•general improvements for Samsung drives
•compatibility issue with Samsung S1 mini fixed
•compatibility issue with OCZ Revodrive fixed (incorrect temperature reported)
進一步修改,錯誤修正:
•improved display and responsible user interface
•improved FTP upload support
•improved disk surface test, display, result processing
•improved e-mail sending with SSL
•file issues fixed
•failed startup on 200% DPI setting
System Requirements :
•Pentium or compatible CPU
•32 megabytes of system memory
•15 megabytes of hard disk space
•Windows operating system (Windows 95, 98, 98SE, ME, NT4, 2000, XP, 2003, 2008, Vista, Windows 7, Windows Home Server) both 32 and 64 bit version
載點:有需要的朋友請找樓主討論! by windata
發表於 2011-7-8 01:04:23 | 顯示全部樓層
印象中  這一軟體可以測出硬碟是不是快要掛點了  可以偵測出SMART狀況跟壞軌數量以及開機使用時數是否達到工作壽命  快速的便利工具 省的每次更換硬碟之後就掛點 是一套很好用的硬碟檢測..壞軌多滴話  就不要用了 省的要救資料 還花更多時間跟金錢  --我有用過DOS版 真低很方便 馬上就知道硬碟可否備份跟使用
GMT+8, 2024-3-28 09:27 PM , Processed in 0.053527 second(s), 19 queries , Gzip On.
