查看: 3118|回復: 0
[檔案管理]QDir 4.57
發表於 2011-6-3 13:35:46 | 顯示全部樓層 |閱讀模式
本帖最後由 windata 於 2011-6-3 02:08 PM 編輯
在 windows 平台,一般的檔案總管用起來好好的,有需要用另一套檔案管理軟體嗎?
一切都是看需求
Q-Dir makes your files and folder easy to manage.
Fast and easy access to your hard disks, network folders, USB-Stiks, floppy disks and other storage devices.
Q-Dir i a good file manager with an amazing Quadro-View technique.
You don't have to renounce the usual, Drag and Drop, all Views, and other functions of your system.
No! Q-Dir gives you other nice functions, that make you happy.
One can save many hand moves and also time!
Q-Dir does not have to be installed and can be executed easily from the desktop, and can be carried on a small usb-stick or other memory device.
More about QDir
The file management in Q-Dir is based on MS Windows Explorer but 4x plus Tabs and with more functionality!
Start the program. The first time that you use it the program it will present you with a license screen. The program is free and the license info is only displayed the first time (per PC).
Operating systems: Windows 7, Windows Server 2008, Windows Vista, Windows 2003, Windows XP, Windows 2000, Windows Me, Windows NT, Windows 98
WARNING : Once Q-Dir, always Q-Dir !!!
Some Features!
Favorites:
Quick access to most often used folders.
Drag&Drop:
Move files by dragging in Q-views, and other programs such as MS Explorer.
Clipboard:
Copy/ Paste between the Q-Dir directory views, and other programs such as MS Explorer.
Folder-Type :
ZIP-, FTP-,cabinet-,network-, system - folders, shortcuts ...
Large icons, tiles, list, detail, thumbnail (Vista: extra large symbols) .
Export:
to XLS, CSV, TXT, HTML.
Popup Menus:
Desktop, My Computer.
Screen magnifier:
anything on the screen can be enlarged.
Color Filter:
Different colors for different item types (e.g. *.log;*.txt).
Highlight-Filter:
Effective way for fast items highlighting.
File-Filter:
Allows for quick and easy filtering of the items.
Columns:
All columns support, and save function .
Quick-Link's:
For fast folder access.
Folder-Select:
Fast & flexible folder selection address-bar/ desktop menu/ my-computer menu/...
Multi-INI:
Several INI files for Q-Dir.
Quadro-View technique:
Quad-Pumped x 16 Tabs, (-: quad core + :-).
Tree-View:
Single and quadruple.
Preview:
Allows a quick preview.
Portable:
from 2.77 is Q-Dir portable.
Printing:
from 3.77 List, Details ... .
Folder size Column:
from 3.83 file and folder size Column.
Settings transfer:
from 3.83 Improved transfer for folder and view settings.
Faster edit:
from 3.86 Faster edit or rename of the files.
File association:
from 3.91 Internal file association rules.
and ........ ;)
官方下載頁 http://www.softwareok.com/?Download=Q-Dir
20110602 4.58
一般版:什麼都沒寫的,相容性最好,適用 windows 98 2000~2008 xp vista 7 x86/x64
Unicode:適用 windows 2000~2008 xp vista 7 x86/x64
x64:本身就是 Unicode,適用
http://www.megaupload.com/?d=0EP9BCW0                458Q-Dir_Installer.zip
http://www.megaupload.com/?d=DJRAEXFR                458Q-Dir_Installer_x64.zip
http://www.megaupload.com/?d=J46J900D                458Q-Dir_Portable_x64.zip
http://www.megaupload.com/?d=OKW42S8A                458Q-Dir_Portable.zip
http://www.megaupload.com/?d=S8KK5XXM                458Q-Dir_Portable_Unicode.zip
http://www.megaupload.com/?d=UPQTB17U                458Q-Dir_Installer_Unicode.zip
GMT+8, 2024-4-20 04:23 PM , Processed in 0.049272 second(s), 19 queries , Gzip On.
