查看: 4688|回復: 1
BitDefender Total Security 2009 & 迅雷 不太合作..
發表於 2009-10-6 02:03:47 | 顯示全部樓層 |閱讀模式
最近電腦重新安裝,本來沒在使用防毒軟體的!後來重灌電腦就裝了BitDefender Total Security 2009
之前有用過前幾代的覺得還不錯,這次安裝了最新版後頻頻出現0X000000D1錯誤
後來仔細試試看,平常待機沒問題!就只有下載的時候才會出現(下載後約一兩分鐘就會籃頻)
我用了騾子跟迅雷都一樣會,問題似乎出在防毒軟體的防火牆!
後來不開防火牆 一切問題都沒囉。 給後來安裝這種防毒的人參考..,
本來我還以為藍頻該不會我硬體出狀況吧,一直試了才發現是防毒在做怪~﹍~
錯誤代碼跟畫面:
(DRIVER_IRQL_NOT_LESS_OR_EQUAL        0x100000d1        0x00000008        0x00000002        0x00000000        0xf706b858        NDIS.sys        NDIS.sys+15858)
A problem has been detected and Windows has been shut down to prevent damage
to your computer.
The problem seems to be caused by the following file: NDIS.sys
If this is the first time you've seen this stop error screen,
restart your computer. If this screen appears again, follow
these steps:
Check to make sure any new hardware or software is properly installed.
If this is a new installation, ask your hardware or software manufacturer
for any Windows updates you might need.
If problems continue, disable or remove any newly installed hardware
or software. Disable BIOS memory options such as caching or shadowing.
If you need to use safe mode to remove or disable components, restart
your computer, press F8 to select Advanced Startup Options, and then
select Safe Mode.
發表於 2009-10-6 14:37:22 | 顯示全部樓層
迅雷偶用過一陣子
也是有出問題
後來就移除不用了
GMT+8, 2024-4-25 08:29 PM , Processed in 0.045585 second(s), 16 queries , Gzip On.
